Star Wars Andor - Season 1 - Only finding first episode on each disk
paul.j
Post by paul.j »
I have a DVD set of Seasons 1 & 2 of Andor, and while MakeMKV is doing everything I expect with the Season 2 disks, I have come across a strange issue with the Season 1 disks. Basically, it goes through the check phase of the disk, but is only finding the first episode on each disk. For example, disk 1 has episodes 1, 2, 3 and 4, but only episode 1 is found. There are no error messages or warnings; it is as if the episodes are not on the disk. If I put the disk in a DVD player, everything is there and can be played.
Is there some way I can sort this so that all the episodes can be downloaded?
I am using MakeMKV 1.18.1 under Gentoo Linux on a desktop computer, and the drive is an ASUS DRW-24D5MT revision 2, with it's own firmware. To test, I also booted up a laptop with Omarchy (Arch) installed, then installed MakeMKV (also 1.18.1), and used a portable LG DVD drive. The result was exactly the same as above.
I have seen reference to "sending a download in" to help with decoding? If this is something I can do to help, please point me at the instructions as to how this should work!
Thanks for reading, and thanks for MakeMKV.
Re: Star Wars Andor - Season 1 - Only finding first episode on each disk
Post by d00zah »
paul.j wrote:
Thu Aug 14, 2025 12:54 pm
Things to try:
DVD opening modes - CellWalk, CellTrim, CellFull
http://www.makemkv.com/manualdvd/
viewtopic.php?p=78478#p78478
paul.j
Post by paul.j »
Thanks @D00zah
The different DVD opening modes didn't give a different result.
Opening in manual mode gives the following messages
Opening files on harddrive at /mnt/cdrom/VIDEO_TS
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
IFO file for VTS #1 is corrupt, VOB file must be scanned. This may take very long time, please be patient.
Open DVD manually : "1:@1;@2;@3;@4;@5"
Title #1 (2:41:48) was skipped due to navigation error
I think I need to study more about the configuration on the DVD - I am not sure if my structure string is correct. I chose my string based on this information in the "Open manually" dialog:
Disc Information
Label :
Titles count : 1
Title information
1: 1/1 - 5 chapter(s) 2:41:48 5 cell(s)
It does, however, feel like the issue is related to reading the disk. I am still open to ideas if you have any more (or anyone else has!).
Post by d00zah »
Conventional wisdom is to recommend cleaning the disc gently, no matter how pristine it may appear to your eye. This may/may not help.
Another thing to try is loading an older version of MakeMKV (v1.6.7?, see sig for link). This may prove problematic if you don't have a permanent key. In that case, try setting system clock to v1.6.7 release date, 2022-02-27, before starting MakeMKV.
