I am getting this error on several of my DVDs using 1.6.12. Most of those I have converted so far worked but about 25% are getting above error. I've tried doing ISOs (which were done without errors) but the same error pops up. Is there a way around this? One thing I've noted: the output size stays around 4.8k while the Read Rate keeps steadily increasing which means data is being read but nothing is being saved. I'm attaching a text file containg a log of the output screen. Hope that helps!
Hmm tried streaming the DVD and all went well...
mkv conversion failed: 0 titles saved, 1 failed
jedimaster
jedimaster
Re: mkv conversion failed: 0 titles saved, 1 failed
Funny. Used DVDFab on the DVDs and was able to use MakeMKV with no errors... Weird since my DVDs are already backed-up DVDs
- Contact:
You have a broken rip ( VOB file is broken ). Please send the full log ( one written by MakeMKV and containing lines like vobs=Zxxx ) to support@makemkv.com, so workaround could be added.
setarip_old
@jedimaster
Hi!
Hi!
Do you have the same problem with MakeMKV if you use the ORIGINAL, COMMERCIAL DVDs (instead of the backup copies) DIRECTLY with MakeMKV instead?Weird since my DVDs are already backed-up DVDs
nexttuesday
I have this same problem periodically with commercially produced disks. Whats up?
