Unable to rip most DVDs with MakeMKV 1.18.1 Linux
aidenn0
Post by aidenn0 »
I have, in the past used older versions of MakeMKV reliably for DVDs. However I just got a new batch and so far 5/6 have failed to rip. The discs are undamaged; I do a backup to .iso in makemkv with no errors. MPV plays both the discs and the .iso dumps just fine. For the two discs with special features, it's only the main feature that fails.
Here's the log from one of the DVDs:
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #10 does not match one in IFO header.
Calculated BUP offset for VTS #11 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
Calculated BUP offset for VTS #13 does not match one in IFO header.
Title #1 was added (12 cell(s), 1:27:10)
Title #4 has length of 115 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 107 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 has length of 99 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Can't locate a cell for VTS 7 TTN 1 PGCN 4 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 5 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 6 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 7 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 8 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 9 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 10 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 12 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 13 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 14 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 15 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 16 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 17 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 18 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 19 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 20 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 21 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 22 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 23 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 24 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 25 PGN 1
Can't locate a cell for VTS 7 TTN 1 PGCN 27 PGN 1
Title #9/1 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9/2 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Can't locate a cell for VTS 8 TTN 1 PGCN 2 PGN 1
Can't locate a cell for VTS 8 TTN 1 PGCN 3 PGN 1
Can't locate a cell for VTS 8 TTN 1 PGCN 4 PGN 1
Can't locate a cell for VTS 8 TTN 1 PGCN 5 PGN 1
Can't locate a cell for VTS 8 TTN 1 PGCN 6 PGN 1
Can't locate a cell for VTS 8 TTN 1 PGCN 7 PGN 1
Can't locate a cell for VTS 8 TTN 1 PGCN 8 PGN 1
Can't locate a cell for VTS 8 TTN 1 PGCN 9 PGN 1
Saving 1 titles into directory REDACTED
DEBUG: Code 0 at z-("}9#Hk~G8Q-Bd;:213130237
DEBUG: Code 3 at JyQ[sci0<Om&Zhn6:121264418
DEBUG: Code 0 at jp5C3/9 )kz!Xo%fEEJ0:121261773
DEBUG: Code 0 at z{J3N9@Fcwb^]g$v@)*@*:121268972
Failed to save title 0 to file REDACTED
0 titles saved, 1 failed
aidenn0
Re: Unable to rip most DVDs with MakeMKV 1.18.1 Linux [SOLVED]
Post by aidenn0 »
The problem is that I updated ccextractor and the argument formats have changed. Possible solutions:
1. Deselect ccextractor from each title; no .srt in the resulting file, but also no issues
2. Use an older ccextractor
3. Write a wrapper script that passes the new argument style
4. ccextractor 0.96.4, released on January 1st adds support for legacy options
flojo
Post by flojo »
So it works again? You now need a version >= 0.96.4 ?
Garnish2108
Post by Garnish2108 »
flojo wrote:
Thu Jan 08, 2026 7:55 pm
I had the same issues with DVDs failing on tracks with subtitles. I tried 0.96.4, 0.96.5, and then 0.96 and I still couldn't extract DVD tracks with subs. I had to build ccextractor 0.94 and that worked for me with makemkv v1.18.2. I am not sure if any of the versions between 0.96 and 0.96.4 work as I didn't test those.
