mkv version 1 6 10 problem with subtitles (to fast)
chimeguy
Post by chimeguy »
mkv version 1 6 10 problem with subtitles (subtitles are flashing to fast)
sometimes on screen for only 2-5 seconds,. this is bad as I watch a lot of foreign movies!!
I did not have this problem with previous versions. previous I had almost always
ripped the dvd to vob folders first then convert to mkv. 4 movies yesterday I converted
straight from DVD to MKV using version 1 6 10 of make mkv.
Re: mkv version 1 6 10 problem with subtitles (to fast)
Post by mike admin »
A known problem in 1.6.10 - will be fixed in the next version.
chimeguy
Post by chimeguy »
when will the new version be out? that means I have to re order and re convert 20 DVDs
all foreign film (subtitles not working)
if this was known issues why was it not posted?
setarip_old
Post by setarip_old »
@chimeguy
Once again (Same as your post in the "General Discussion" sub-forum):
@chimeguy
By "re order", do you mean it's a big deal to put 20 DVDs in a specific sequence - or do you mean something else?
