Backyardigins: Robot Repairman
Looking at VLC media player when watching having navigated via the DVD menu the tracks should be 43 44 and 45 for the individual episodes or 46 for the play all. But Make MKV only finds a 6.33 min track of some previews.
Additionally might I note, it would be great if I could tell Make MKV - 'Just try this particular track.' Maybe integrate it with a player and let me navigate to the title via the DVD menu then just click a big red "Make this title into an MKV" button. If makeMKV could watch me navigate the menu and queue up titles I select it would be perfect. As it is it spends a lot of time deciphering crud I could just tell it to skip.
MakeMKV v1.6.8 win(x64-release) started
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Calculated BUP offset for VTS #4 does not match one in IFO header.
Calculated BUP offset for VTS #6 does not match one in IFO header.
Calculated BUP offset for VTS #7 does not match one in IFO header.
Calculated BUP offset for VTS #8 does not match one in IFO header.
Calculated BUP offset for VTS #9 does not match one in IFO header.
Calculated BUP offset for VTS #12 does not match one in IFO header.
CellWallk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
CellTrim algorithm failed since title has only 3 chapters
Title #42 (0:43:30) was skipped due to navigation error
CellTrim algorithm failed since title has only 2 chapters
Title #43 (0:23:10) was skipped due to navigation error
CellTrim algorithm failed since title has only 1 chapters
Title #44 (0:23:10) was skipped due to navigation error
CellTrim algorithm failed since title has only 4 chapters
Title #45 (1:29:50) was skipped due to navigation error
Cells 1-8 were removed from title start
Cells 15-15 were removed from title end
Title #91 was added (6 cell(s), 0:06:33)
Title #92 was added (6 cell(s), 0:06:33)
Title #97 has length of 4 seconds which is less than minimum title length of 180 seconds and was therefore skipped
Title 2 in VTS 11 is equal to title 1 and was skipped
- Contact:
Re: Backyardigins: Robot Repairman
Please send all IFO files and log per instructions at http://www.makemkv.com/faq/item/8/catid/6
