Hello All
I was making a backup of "The Secrets of Dumbledore" and the system seems to only get a short way and gets stuck and does not move, sitting stagnant for 50 minutes. Not sure why this is happening, it just did another title just before it no problem...
Debug log started at Wed Jul 06 16:24:24 2022 , written by MakeMKV v1.17.0 win(x64-release)
001005:0000 MakeMKV v1.17.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\Administrator/MakeMKV_log_1.txt
No SDF v08d: HL-DT-ST_DVD-ROM_DU60N_D301_201203121321_KXJC7435559
DEBUG: Code 3 at 4^=z<Kvs'aZ>Dxn+E!~8apE::29395310
SDF id v08d: HL-DT-ST_DVD-ROM_DU60N_D301_201203121321_KXJC7435559
No SDF v08d: Dell_DVD+/-RW_DW316_A1C0_201601201031_KX3Z7IG5710
No auto SDF v08d: Dell_DVD+/-RW_DW316_A1C0_201601201031_KX3Z7IG5710
DEBUG: Code 0 at ao[X*Bcvc?%qM,+:D:121264142
DEBUG: Code 0 at ]M#HK*gdYnz32A^n:213136769
SDF id v08d: Dell_DVD+/-RW_DW316_A1C0_201601201031_KX3Z7IG5710
Launching C:\Users\Administrator\New folder\make mkv\MakeMKV\mmgplsrv64.exe
v 1.17.0 x64 stuck
- Contact:
