DVD initializes(http://www.amazon.com/Requiem-Dream-Edi ... B00005QCVT), or at least it seems to. It only has one title greater than 2 min containing only one audio tracks. Fails as soon as you try to rip the first title.
Title #0 was added (34 cell(s), 1:40:54)
Title #2 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 94 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory D:/Video/REQUIEM_DREAM_R
Failed to save title 0 to file D:/Video/REQUIEM_DREAM_R/title00.mkv
0 titles saved, 1 failed
Requiem for a Dream: Edited Version
setarip_old
Re: Requiem for a Dream: Edited Version
Hi!
Does the original, commercial DVD play properly on your computer?
- Contact:
Please post a debug log per http://www.makemkv.com/faq/item/8/catid/6
The DVD does play on the same computer.
Attached log
Attached log
