No Audio?
Riekardo
No Audio?
Post by Riekardo »
I've been ripping all my South Park DVD's to Seperate episodes because that's just much easier to play on my Mediaplayer.
Now i've done 12 seasons and wanted to do the 13th but i've encountered a problem with the audio.
I ripped the first 5 episodes from DVD1, but the first episode does not have audio when i play it.
The 4 other episodes do have audio.
I've retried it many times, I checked Audio DD 2/0 English 2 times (because it's in the list two times, i don't know why, but it worked with every 12 seasons) I tried German too, just to be sure. I tried 1 of the English audio only and then the other, but there is just no audio.
Does anyone know how i could solve this?
When i play the first episode from the dvd it has audio..
setarip_old
Re: No Audio?
Post by setarip_old »
Hi!
Is this the audio format of the other 4 episodes?
Riekardo
Re: No Audio?
Post by Riekardo »
Yes, every episode has DD 2/0 English (english is in the list two times, so i always keep them both checked since i don't know the difference) I only uncheck the other languages.
But i've also tried it with all languages checked, no audio. :( only on that episode
Re: No Audio?
Post by mike admin »
Please post mediainfo output of produced MKV file.
Riekardo
Re: No Audio?
Post by Riekardo »
Ok, here is the output:
General
Unique ID                        : 245662646586321343275328545774576557905 (0xB8D0E79C3DBF3DE6D630D669B3E35F51)
Complete name                    : D:\Video\South Park Season 13\title00.mkv
Format                           : Matroska
File size                        : 712 MiB
Duration                         : 23mn 26s
Overall bit rate                 : 4 246 Kbps
Encoded date                     : UTC 2011-01-25 19:01:12
Writing application              : MakeMKV v1.6.3 win(x64-release)
Writing library                  : libmakemkv v1.6.3 (0.7.7/0.8.1) win(x64-release)
Video
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@Main
Format settings, BVOP            : No
Format settings, Matrix          : Default
Codec ID                         : V_MPEG2
Codec ID/Info                    : MPEG 1 or 2 Video
Duration                         : 23mn 26s
Bit rate mode                    : Variable
Bit rate                         : 3 777 Kbps
Nominal bit rate                 : 9 800 Kbps
Width                            : 720 pixels
Height                           : 576 pixels
Display aspect ratio             : 16:9
Frame rate                       : 25.000 fps
Standard                         : PAL
Color space                      : YUV
Chroma subsampling               : 4:2:0
Bit depth                        : 8 bits
Scan type                        : Interlaced
Scan order                       : Top Field First
Compression mode                 : Lossy
Bits/(Pixel*Frame)               : 0.364
Stream size                      : 633 MiB (89%)
Language                         : English
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 23mn 26s
Bit rate mode                    : Constant
Bit rate                         : 192 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Sampling rate                    : 48.0 KHz
Bit depth                        : 16 bits
Stream size                      : 32.2 MiB (5%)
Title                            : 2/0
Language                         : English
Audio #2
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 23mn 26s
Bit rate                         : 192 Kbps
Bit depth                        : 16 bits
Title                            : 2/0
Language                         : English
Text #1
Format                           : VobSub
Codec ID                         : S_VOBSUB
Codec ID/Info                    : The same subtitle format used on DVDs
Language                         : Dutch
Text #2
Format                           : VobSub
Codec ID                         : S_VOBSUB
Language                         : Dutch
Menu
00:00:00.000                     : en:Chapter 01
