Can't Rip - Drive Just Spins
jwrusa
Post by jwrusa »
This is the first time I have experienced this:
1. The program preloads everything fine.
2. I tick off the files I need ripped, choose drive and hit Make MKV
3. The drive just spins - first at a high rate then slows down. Progress bar doesn't fill out.
I'm ripping a commercial DVD with DRM.
Can anyone help?
Re: Can't Rip - Drive Just Spins
Debug log would help a lot - see the FAQ link in my signature if you are unfamiliar with debug mode.
jwrusa
Post by jwrusa »
MakeMKV v1.14.7 darwin(x64-release) started
Optical drive "DVD+R-DL HL-DT-ST DVDRW GX40N RQ00d" opened in OS access mode.
Title #1 was added (9 cell(s), 1:30:11)
Title #2 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #8 was added (1 cell(s), 0:09:18)
Title #9 was added (1 cell(s), 0:07:55)
Title #10 was added (1 cell(s), 0:02:50)
Subtitle stream #3 is identical to stream #2 and was skipped
Saving 1 titles into directory /Users/jesperrasmussen/Desktop/Film
jwrusa
Post by jwrusa »
Sorry, here is the report:
Debug logging enabled, log will be saved as /Users/jesperrasmussen/MakeMKV_log.txt
DEBUG: Code 0 at "&$/59j/-[L)LSC\g5|G:29394022
DEBUG: Code 0 at 4gR9l=vu8d2skdQEfM3}-:213136608
DEBUG: Code 0 at "&$/59j/-[L)LSC\g5|G:29404257
DEBUG: Code 0 at "&$/59j/-[L)LSC\g5|G:29404763
DEBUG: Code 0 at "&$/59j/-[L)LSC\g5|G:213139759
DEBUG: Code 1 at Pid0L$wW<Oi^rbm=:29395310
DEBUG: Code 0 at Pid0L$wW<Oi^rbm=:213133250
DEBUG: Code 0 at B+mIsYmnIAn;);L:\dP::29393286
Failed to save title 0 to file /Users/jesperrasmussen/Desktop/Film/MANHATTAN MELODRAMA_t00.mkv
0 titles saved, 1 failed
The debug 0 errors usually appear when MakeMKV is having trouble getting proper responses from the drive, such as when it is having trouble reading the disk. Have you tried cleaning the disk?
jwrusa
Post by jwrusa »
It seems to be all the discs in this one collection:
https://www.amazon.com/William-Collecti ... B000Q7ZLUG
Other discs work fine. Just tested a few.
Tested another drive as well. Same issue.
Very strange ...
The "spinning endlessly" actually looks like this issue, given that this is a "classic" DVD set:
viewtopic.php?p=82134#p82134
I encountered it on "Gone with the Wind".
jwrusa
Post by jwrusa »
Now it seems to work - just took forever to get going!
Thanks for trying to solve my issue, man :-)
