Cannot cinvert Chapter 4 from ATHF.S1.D2
nzdreamer55
Post by nzdreamer55 »
I was able to get the first disk and all of the titles on disk #2 except title #4 from Aqua Teen hunger Force Season 1. There are 2 disc and the second disc is where I had the problem
Here is the debug log
Debug log started at Sun Nov 07 03:36:58 2010 , written by MakeMKV v1.6.2 win(x64-release)
001005:0000 MakeMKV v1.6.2 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Admin/MakeMKV_log.txt
003002:0000 Calculated BUP offset does not match one in IFO header.
003028:0000 Title #0 was added (9 cell(s), 1:45:28)
003025:0000 Title #1 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003028:0000 Title #2 was added (1 cell(s), 0:11:39)
003028:0000 Title #3 was added (1 cell(s), 0:11:24)
003028:0000 Title #4 was added (1 cell(s), 0:11:33)
003028:0000 Title #5 was added (1 cell(s), 0:11:45)
003028:0000 Title #6 was added (1 cell(s), 0:11:18)
003028:0000 Title #7 was added (1 cell(s), 0:12:00)
003028:0000 Title #8 was added (1 cell(s), 0:11:56)
003028:0000 Title #9 was added (1 cell(s), 0:11:59)
003028:0000 Title #10 was added (1 cell(s), 0:11:54)
003025:0000 Title #11 has length of 31 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #12 has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #14 has length of 36 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #15 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory F:/Video/AQUA_TEEN_HUNGER_FORCE
001003:0020 DEBUG: Code 2114 at IRA_H;]'tP~\ViBpg-3:121262716
vobs=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
001003:0020 DEBUG: Code 0 at 4[XX/VGo,o,itCCBLt{E:29394183
001003:0020 DEBUG: Code 20943 at 4[XX/VGo,o,itCCBLt{E:29393309
005003:0000 Failed to save title 4 to file F:/Video/AQUA_TEEN_HUNGER_FORCE/title04.mkv
005004:0080 0 titles saved, 1 failed
Application exited at Sun Nov 07 03:51:57 2010
Steve
Re: Cannot cinvert Chapter 4 from ATHF.S1.D2
Post by mike admin »
The log makes no sense at all. I'll ask you to do a silly thing - please reboot the computer, try to convert this disc again and see if it fails again at that place.
nzdreamer55
That is a silly thing! I'll try again after reboot. Thanks.
Steve
setarip_old
Post by setarip_old »
So, does it work properly now?
Naomi15
Post by Naomi15 »
It doesn't work with these DVDs at all
MakeMKV v1.17.7 darwin(arm64-release) started
Optical drive "BD-RE PIONEER BD-RW BDR-UD04 1.14 CKDL122772WLd" opened in OS access mode.
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Title #1 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #2 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 was added (28 cell(s), 1:45:26)
14 years later, your log shows that a 1:45:26 track was found. What happened when you tried to rip it?
