A Prophet
anthonyp
A Prophet
Post by anthonyp »
Hi all
My first post here and the first time I have had a problem with a DVD rip :(
"A Prophet" isn't ripping at all. The only thing that rips is a trailer.
I have uploaded the log file output. Cheers, Ant
setarip_old
Re: A Prophet
Post by setarip_old »
Hi!
003015:0000 Title #0 (2:28:52) was skipped due to navigation error
Have you checked to see if the disc is either physically damaged or dirty? Even if it doesn't look dirty, try cleaning it carefully (Look carefully for fingerprints)
Re: A Prophet
Post by mike admin »
Please send IFO files and this log per instructions at http://www.makemkv.com/faq/item/8/catid/6
anthonyp
Re: A Prophet
Post by anthonyp »
setarip_old wrote:Hi!
Hi there - yes you must have been right about the disk. It didn't look damaged, but I got another copy of the movie and it ripped fine. Thanks, Ant
setarip_old
Re: A Prophet
It's always gratifying to hear that a suggested simple solution worked ;>}
