TMNT Retail R1 DVD
LesSr79
TMNT Retail R1 DVD
Post by LesSr79 »
Retail DVD Barcode # 794043412127
Debug log started at Thu Oct 07 23:35:09 2010 , written by MakeMKV v1.6.0 win(x64-release)
001005:0000 MakeMKV v1.6.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Les Sr/MakeMKV_log.txt
001003:0020 DEBUG: Code 134219780 at ~q#Mu\Z-6gLooXxPn:121261957
001003:0020 DEBUG: Code 0 at ~q#Mu\Z-6gLooXxPn:121263774
003031:0000 Drive BD-ROM ATAPI iHOS104 WL0D has RPC protection that can not be bypassed. Change drive region or update drive firmware from http://tdb.rpc1.org. Errors likely to follow.
001003:0020 DEBUG: Code 9412 at ,0uVM?5>(j$D o5l+I:121265016
001003:0020 DEBUG: Code 0 at ,0uVM?5>(j$D o5l+I:213136424
001003:0020 DEBUG: Code 0 at ,0uVM?5>(j$D o5l+I:121268604
003015:0000 Title #0 (1:33:23) was skipped due to navigation error
003025:0000 Title #1 has length of 24 seconds which is less than minimum title length of 4760 seconds and was therefore skipped
003025:0000 Title #2 has length of 91 seconds which is less than minimum title length of 4760 seconds and was therefore skipped
003025:0000 Title #3 has length of 67 seconds which is less than minimum title length of 4760 seconds and was therefore skipped
003025:0000 Title #4 has length of 141 seconds which is less than minimum title length of 4760 seconds and was therefore skipped
003025:0000 Title #5 has length of 113 seconds which is less than minimum title length of 4760 seconds and was therefore skipped
Re: TMNT Retail R1 DVD
Post by mike admin »
That's what it says - mismatched disc region and a bad luck.
jabster
Post by jabster »
Hi.
I'm getting the RPC protection error as well (Mel Brooks To Be Or Not To Be). So there's really no way around that? What are the odds of it being bypassable at some point in the future?
thanks,
john
