I have one DVD on my HD, that at some points, it says:
Complex multiplex encountered - 8 cells and 4928 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
Then, instead of going to 4928, MakeMKV goes to 2 million something, and it kills Windows 7, 64 bits, at a point where i have no more options to turn off the machine.
Any ideas?
Win7 x64 Killed by "Complex multiplex encountered"
Re: Win7 x64 Killed by "Complex multiplex encountered"
Hi!
1) What is the title and region of your original, commercial DVD?
2) Use MakeMKV DIRECTLY with your original, commercial DVD
- Contact:
Wow. Please send ifo files per http://www.makemkv.com/faq/item/8/catid/6kwanbis wrote:Then, instead of going to 4928, MakeMKV goes to 2 million something, and it kills Windows 7, 64 bits, at a point where i have no more options to turn off the machine.
I just sent you the files.
I had to quit MakeMKV, cause cancelling the part where it breaks, would not work, and it only gives me some seconds till it crashes W7.
EDIT: WOW, even if closed MakeMKV, i had to turn off the machine, as W7 started to not respond!
Did you try using MakeMKV DIRECTLY with your original, commercial DVD?
I actually store my originals on a friends house, and have the backups with me (he does the same), just in case.
I would need to get them, but not possible that quick.
So, what is the title and region of the DVD?
I and/or other members may have the same release and may be able to compare...
The dvd is called "Las Mu?ecas de la Mafia", is the 1st DVD, is a colombian TV series.
By the way, VOB2MPG was able to process it without issues.
