Mr Selfridge, S4D1
Winebum
Mr Selfridge, S4D1
Post by Winebum »
When trying to rip Ep. 1-3 of season 4 of Mr. Selfridge, MakeMKV only identifies Episode 1 & 2. Ep. 3 is not listed. Episode 1 & 2 rip correctly and play as expected. Here is the log entry...
Calculated BUP offset for VTS #0 does not match one in IFO header.
Title #3 was added (6 cell(s), 0:45:30)
Title #5 was added (2 cell(s), 0:01:24)
Title #6 was added (2 cell(s), 0:03:00)
DEBUG: Code 10551311 at SJ*@jg/<lv-`O[VY:213142128
DEBUG: Code 0 at SJ*@jg/<lv-`O[VY:213143301
DEBUG: Code 0 at %`~=(gEentO3T:$#8S:29394229
CellWalk algorithm failed (structure protection is too tough?), trying CellTrim algorithm
Cells 1-1 were removed from title start
Title #32 was added (6 cell(s), 0:45:39)
I've tried forcing each 'Protection' option (Auto, CellWalk, CellTrim); result is always the same. And whether ripping from the DVD or an ISO, the result is always the same. I've experienced this phenomenon on another PBS recent release, Poldark. Any ideas?
EDITED/ADDITIONAL - Apparently, this phenomenon occurs on each of the 3 disks, where MakeMKV does not recognize or acknowledge the last episode on the respective DVD. The 3 Debug lines above are repeated for each of the 3 disks.
Re: Mr Selfridge, S4D1
Follow the procedure in the FAQ link in my signature, and send the files to support@makemkv.com for Mike to look at.
jepilo
Post by jepilo »
I have the same problem to identify the correct files with Mr Selfridge season 4.
Disc one : I have identified episode 1 (t137) & 2 (t246) but episode 3 is hidden.
Disc two : 300 identical titles, impossible to find episode 4, 5, 6 & 7.
Disc three : Episode 9 (t76) and 10 (t111) identified, episode 8 missing.
Is there a method to find them ? (without ripping the whole 300 titles !)
Thanks for your help.
Best regards,
jepilo.
jepilo
Post by jepilo »
so, I've read the topic about "fake Playlist" protection - help needed.
Well, does anybody has already ripped the season 4 of Mr Selfridge and can give me the correct playlist of the 3 discs ?
A repack of season 4 exist, made by the team YELLOWBiRD which is the best quality we can find, but unfortunately no remux or ISO.
Thanks for your help !
jepilo
Post by jepilo »
Hello winebum !
Do you have found the correct playlist for the season 4 of Mr Selfridge ?
I would be interrested !
Best regards,
jepilo.
jepilo
Post by jepilo »
Okay, I've done the job myself using AnyMP4 Blu-ray Player.
In fact, there was 1 episode per disc really hidden in the 300 titles.
The other episodes were easier to find when looking at the duration of the files.
Here is the correct playlist :
disc 1 : Mr Selfridge Season 4 Disc 1 _t137.mkv Episode 1
Mr Selfridge Season 4 Disc 1 _t246.mkv Episode 2
Mr Selfridge Season 4 Disc 1 _t72.mkv Episode 3
disc 2 : Mr Selfridge Season 4 Disc 2 _t153.mkv Episode 4
Mr Selfridge Season 4 Disc 2 _t200.mkv Episode 5
Mr Selfridge Season 4 Disc 2 _t267.mkv Episode 6
Mr Selfridge Season 4 Disc 2 _t202.mkv Episode 7
disc 3 : Mr Selfridge Season 4 Disc 3 _t204.mkv Episode 8
Mr Selfridge Season 4 Disc 3 _t76.mkv Episode 9
Mr Selfridge Season 4 Disc 3 _t111.mkv Episode 10
Enjoy ! 8)
K1LJ0YX
Post by K1LJ0YX »
@ jepilo How did you find the correct playlist using "AnyMP4 Blu-ray Player"? I tried using the titles you found but I am almost certain I have a different disc.
K1LJ0YX
Post by K1LJ0YX »
Actually, I may have just figured it out myself thanks to the information provided by 'bottleneck70' on a different article which I will link here: viewtopic.php?t=8759
This is the correct playlist for anyone interested:
Disc 1:
Episode 1
Name: Mr. Selfridge Season 4 Disc 1
Source file name: 00451.mpls
Duration: 0:45:38
Chapters count: 5
Segment count: 1
Segment map: 8
File name: Mr. Selfridge Season 4 Disc 1_t138.mkv
Episode 2:
Source file name: 00808.mpls
Duration: 0:45:30
Chapters count: 5
Segment count: 1
Segment map: 12
File name: Mr. Selfridge Season 4 Disc 1_t247.mkv
Episode 3:
Source file name: 00245.mpls
Duration: 0:47:04
Chapters count: 5
Segment count: 15
Segment map: 113,109,107,111,102,114,105,108,110,104,103,2,106,115,112
File name: Mr. Selfridge Season 4 Disc 1_t73.mkv
Disc 2
Episode 4:
Name: Mr. Selfridge Season 4 Disc 2
Source file name: 00497.mpls
Duration: 0:46:10
Chapters count: 5
Segment count: 1
Segment map: 8
File name: Mr. Selfridge Season 4 Disc 2_t154.mkv
Episode 5:
Source file name: 00653.mpls
Duration: 0:47:05
Chapters count: 5
Segment count: 15
Segment map: 105,111,108,104,110,115,107,109,2,103,114,113,116,102,112
File name: Mr. Selfridge Season 4 Disc 2_t203.mkv
Episode 6:
Source file name: 00875.mpls
Duration: 0:46:45
Chapters count: 5
Segment count: 1
Segment map: 13
File name: Mr. Selfridge Season 4 Disc 2_t268.mkv
Episode 7:
Source file name: 00649.mpls
Duration: 0:46:55
Chapters count: 5
Segment count: 1
Segment map: 15
File name: Mr. Selfridge Season 4 Disc 2_t201.mkv
Disc 3
Episode 8:
Name: Mr. Selfridge Season 4 Disc 3
Source file name: 00709.mpls
Duration: 0:46:58
Chapters count: 5
Segment count: 15
Segment map: 102,103,109,106,107,114,105,112,110,104,113,116,111,108,2
File name: Mr. Selfridge Season 4 Disc 3_t205.mkv
Episode 9:
Source file name: 00246.mpls
Duration: 0:44:33
Chapters count: 5
Segment count: 1
Segment map: 12
File name: Mr. Selfridge Season 4 Disc 3_t77.mkv
Episode 10:
Source file name: 00331.mpls
Duration: 0:45:00
Chapters count: 5
Segment count: 1
Segment map: 13
File name: Mr. Selfridge Season 4 Disc 3_t102.mkv
smr888
Post by smr888 »
You have my grateful thanks for posting this. I had no idea how to unravel the final season of Mr. Selfridge. I appreciate your fine work.
