v1.9.1 Fails to rip BD under Debian Jessie: Error Scsi error
richEQ
Post by richEQ »
I succesefully ripped BD disks using my USB3 BD reader under windows 7.
Using the same drive and disks I always get this output when trying to rip under debian Linux:
"MakeMKV v1.9.1 linux(x64-release) started
Backing up disc into folder "/home/rich/Videos/backup/DESPICABLEME2_G51"
Evaluation version, 9 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:1'
Highest AACS version is v50 , MKB saved as /home/rich/.MakeMKV/MKB_v50_20000_DAYS_ON_EARTH.tgz
Backup failed
Am I missing a key piece of the installation process?
What information can I provide to help fix this probelm?
Rich
ps this is my first post, so please go easy if I've erred
Re: v1.9.1 Fails to rip BD under Debian Jessie: Error Scsi e
Several factors can come into play with Linux, when using the same hardware that "works with Windows".
One is permission to make some of the requests MakeMKV has to do to control the drive. Depending upon your configuration, that could require it be run with SU privileges.
richEQ
Post by richEQ »
Thanks for the reply Woodstock.
Sadly it's not that.
Hopefully attached the log file which may help, but broadly, exactly the same... :-/
FWIW, i've tried the solution posted here, to no avail:
http://www.makemkv.com/forum2/viewtopic ... 370#p30969
The debug listing is bradly meaningless to me. though I appear to have company
google:"...SCSI command AD010..080002400..." reveals several hits with similar problems
What next?
ps can't attach the file I get this:"Sorry, the board attachment quota has been reached."
tail of the file looks like:
"002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:2'
DEBUG: Code 0 at !s8Qu#!=(X"m|#xyt:213130306
001003:0020 DEBUG: Code 0 at BJ8F{OS?&x{Z8\,^9(:29396345
001003:0020 DEBUG: Code 2 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 0 at !s8Qu#!=(X"m|#xyt:213130582
001003:0020 DEBUG: Code 0 at BJ8F{OS?&x{Z8\,^9(:29395195
001003:0020 DEBUG: Code 3 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 4 at BJ8F{OS?&x{Z8\,^9(:121262647
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
003341:0000 Highest AACS version is v44 , MKB saved as /root/.MakeMKV/MKB_v44_Cloudy_2.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at .&:+:k~<nm6=d1H(:213131985
001003:0020 DEBUG: Code 0 at r(I^Ona_,`d]&U"ay3G:29403889
001003:0020 DEBUG: Code 0 at b-!hNPw/-zpyjvHG0<\.:29396851
005069:0080 Backup failed
005080:0204 Backup failed.
If the log is under about 55K in size, you can put it in your message here.
What's really needed is the first part of the log, when MakeMKV is trying to communicate with the drive. You can also try "opening" the disk (rather than select Backup), which will look at more information before the rip starts.
richEQ
Post by richEQ »
Evening Woodstock
you asked for it! :-)
20K of MakeMKV_log.txt:
Debug log started at Sun Feb 1 22:03:48 2015 , written by MakeMKV v1.9.1 linux(x64-release)
001005:0000 MakeMKV v1.9.1 linux(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /root/MakeMKV_log.txt
005050:0000 Evaluation version, 30 day(s) out of 30 remaining
DAFD=PAAAADAAAAEABDQUEAAACAQ==
001003:0020 DEBUG: Code 0 at BJ8F{OS?&x{Z8\,^9(:121262647
001003:0020 DEBUG: Code 1 at BJ8F{OS?&x{Z8\,^9(:121262647
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_11:1'
001003:0020 DEBUG: Code 0 at .&:+:k~<nm6=d1H(:121265407
005072:0000 Backing up disc into folder "/root/Videos/backup/DESPICABLEME2_G51"
Application exited at Sun Feb 1 22:06:34 2015
FYI, both before and after this I can rip the disk with the same drive under Win7 :-/
W' are you one of the authors, or just a concerned bystander?
I appreciate you looking into this with/for me!
Rich
Concerned bystander. There are a lot of common errors that can be picked out from the logs, so Mike (the author) gets the juicy ones, like this.
The debug codes are MakeMKV trying a variety of things to get around issues it sees in the data stream, and Mike is the one who knows what they mean. Since he isn't here every day, I'd suggest forwarding this log to support@makemkv.com so that he can see it sooner, and point him at this topic for the other details, like that Windows works, but Linux complains.
