Blu ray automatic language selection
cableguy8007
Post by cableguy8007 »
Hi.
I noticed that when I rip a dvd, it automatically selects the primary title and my preferred language. It is pretty useful because I often rip many movies ones after ones. But When the movie I want to rip is on a blu ray support, mkv maker selects automatically every titles and every languages. Is it a bug or a wrong configuration? I'm a litle bit confused in face of this situation. Is there somebody who have faced this problem with mkv maker, is there an easy solution to solve this problem?
Thanks for your help.
Re: Blu ray automatic language selection
Are you sure you're talking MakeMKV, and not some other program?
The default behavior of MakeMKV is to select all titles, whether it be a DVD or BD. You can set up rules to select audio and subtitle tracks within a title based upon your preferences.
cableguy8007
Yes I'm sure I'm talking about makemkv. MakeMKV v1.9.0 linux x64 release
cableguy8007
I'm riping a blu ray but as soon I finish riping it I send you a print screen of what it does when I open a DVD
