patgul
Posts: 5 Joined: Tue Nov 12, 2013 7:29 pm
Post
by patgul » Tue Nov 12, 2013 7:38 pm
i'm running debian testing with packages from deb-multimedia.org:
libavcodec-dev:amd64 10:1.2.4-dmo3
libavcodec54:amd64 10:1.2.4-dmo3
However, make for oss is failing with:
? makemkv-oss-1.8.6 make -f makefile.linux
mkdir -p out
gcc -Os -D_GNU_SOURCE -D_linux_ -D_REENTRANT -shared -Wl,-z,defs -oout/libmakemkv.so.1.full -Ilibebml/inc -DEBML_NO_READ -DEBML_STRICT_API -Ilibmatroska/inc \
-Ilibmakemkv/inc -Isstring/inc -Imakemkvgui/inc -Ilibabi/inc -Ilibffabi/inc \
libebml/src/EbmlBinary.cpp libebml/src/EbmlContexts.cpp libebml/src/EbmlCrc32.cpp libebml/src/EbmlDate.cpp libebml/src/EbmlDummy.cpp libebml/src/EbmlElement.cpp libebml/src/EbmlFloat.cpp libebml/src/EbmlHead.cpp libebml/src/EbmlMaster.cpp libebml/src/EbmlSInteger.cpp libebml/src/EbmlString.cpp libebml/src/EbmlSubHead.cpp libebml/src/EbmlUInteger.cpp libebml/src/EbmlUnicodeString.cpp libebml/src/EbmlVersion.cpp libebml/src/EbmlVoid.cpp libebml/src/IOCallback.cpp libebml/src/MemIOCallback.cpp libmatroska/src/FileKax.cpp libmatroska/src/KaxAttached.cpp libmatroska/src/KaxAttachments.cpp libmatroska/src/KaxBlock.cpp libmatroska/src/KaxBlockData.cpp libmatroska/src/KaxChapters.cpp libmatroska/src/KaxCluster.cpp libmatroska/src/KaxClusterData.cpp libmatroska/src/KaxContentEncoding.cpp libmatroska/src/KaxContexts.cpp libmatroska/src/KaxCues.cpp libmatroska/src/KaxCuesData.cpp libmatroska/src/KaxInfo.cpp libmatroska/src/KaxInfoData.cpp libmatroska/src/KaxSeekHead.cpp libmatroska/src/KaxSegment.cpp libmatroska/src/KaxTag.cpp libmatroska/src/KaxTags.cpp libmatroska/src/KaxTrackAudio.cpp libmatroska/src/KaxTrackEntryData.cpp libmatroska/src/KaxTracks.cpp libmatroska/src/KaxTrackVideo.cpp libmatroska/src/KaxVersion.cpp libmakemkv/src/ebmlwrite.cpp libmakemkv/src/libmkv.cpp libmakemkv/src/version.cpp libmakemkv/src/world.cpp sstring/src/sstring.cpp \
libabi/src/ossl_aes.c libabi/src/ossl_sha.c libabi/src/ossl_ec.c libabi/src/zlib.c libabi/src/xpat.c libabi/pssl/ec_key.c libabi/pssl/ec_lib.c libabi/pssl/ec_cvt.c libabi/pssl/ec_mult.c libabi/pssl/ecp_mont.c libabi/pssl/ecp_smpl.c libabi/pssl/ecs_ossl.c libabi/pssl/ecs_sign.c libabi/pssl/ecs_vrf.c libabi/src/httplinux.cpp makemkvgui/src/api_linux.cpp libabi/src/sys_linux.c makemkvgui/src/spawn_posix.cpp libffabi/src/ffabi.c libffabi/src/mlp.c libffabi/src/log.c libffabi/src/audio_convert.c \
-DHAVE_BUILDINFO_H -Itmp \
-fPIC -Xlinker -dy -Xlinker --version-script=libmakemkv/src/libmakemkv.vers \
-Xlinker -soname=libmakemkv.so.1 -lc -lstdc++ -lcrypto -lz -lexpat -lavcodec -lavutil -lm
libffabi/src/ffabi.c: In function ‘ffm_audio_decode_init’:
libffabi/src/ffabi.c:166:15: error: ‘AVCodecContext’ has no member named ‘refcounted_frames’
ctx->avctx->refcounted_frames = 1;
libffabi/src/ffabi.c: In function ‘ffm_audio_encode_init’:
libffabi/src/ffabi.c:321:15: error: ‘AVCodecContext’ has no member named ‘refcounted_frames’
make: *** [out/libmakemkv.so.1.full] Error 1
I'm stuck with this, any help is appreciated!
Regards
belegdol
Posts: 26 Joined: Mon Mar 05, 2012 5:30 pm
Post
by belegdol » Tue Nov 12, 2013 9:16 pm
All I can tell you is that you need fairly recent ffmpeg, 2.1.0 works.
patgul
Post
by patgul » Tue Nov 12, 2013 9:48 pm
Thanks for the tip. So it seems that i have to build ffmpeg 2 by myself, i'll try it tomorrow...
Posts: 4108 Joined: Wed Nov 26, 2008 2:26 am
Post
by mike admin » Wed Nov 13, 2013 9:43 am
patgul wrote: I'm stuck with this, any help is appreciated!Regards
It should work. Can you figure out what kind of libavcodec.h do you have is it from libav or from ffmpeg? What is the version (cat libavcodec/version.h)?
ylood
Posts: 2 Joined: Wed Nov 13, 2013 1:43 pm
Post
by ylood » Wed Nov 13, 2013 1:46 pm
I have the same problem with CentOS 6 and ffmpeg-devel from the ATrpms.net repo: ffmpeg-devel-1.2.3-59.el6.x86_64
The libavcodec/version.h :
#define LIBAVCODEC_VERSION_MAJOR 54
#define LIBAVCODEC_VERSION_MINOR 92
#define LIBAVCODEC_VERSION_MICRO 100
Romansh
Posts: 873 Joined: Sat Jan 22, 2011 7:09 pm
Post
by Romansh » Wed Nov 13, 2013 4:42 pm
mike admin wrote: patgul wrote: I'm stuck with this, any help is appreciated!Regards
FWIW, refcounting is very recent (only FFmpeg 2.0 or later, and not yet in any Libav release).
patgul
Post
by patgul » Wed Nov 13, 2013 6:41 pm
Hi, it's from ffmpeg and version.h gives the same on my side:
Regards
-- EDIT --
Just tried it with a fresh debian jessie VM, it gives the same error. Although libavcodec in this case is from libav...
barney_1
Posts: 2 Joined: Wed Nov 13, 2013 10:40 pm
Post
by barney_1 » Wed Nov 13, 2013 10:46 pm
I also cannot get 1.8.6 to compile.
I've tried it with both the git version and version 2.1 of FFMEG:
ffmpeg -version
ffmpeg version 2.1
built on Nov 12 2013 23:10:15 with gcc 4.6 (Ubuntu/Linaro 4.6.3-1ubuntu5)
configuration: --prefix=/home/barney/ffmpeg_build --extra-cflags=-I/home/barney/ffmpeg_build/include --extra-ldflags=-L/home/barney/ffmpeg_build/lib --bindir=/home/barney/bin --extra-libs=-ldl --enable-gpl --enable-libass --enable-libfdk-aac --enable-libmp3lame --enable-libopus --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-nonfree --enable-x11grab
libavutil 52. 48.100 / 52. 48.100
libavcodec 55. 39.100 / 55. 39.100
libavformat 55. 19.104 / 55. 19.104
libavdevice 55. 5.100 / 55. 5.100
libavfilter 3. 90.100 / 3. 90.100
libswscale 2. 5.101 / 2. 5.101
libswresample 0. 17.104 / 0. 17.104
libpostproc 52. 3.100 / 52. 3.100
But it bombs out with the same AVCodecContext error:
mkdir -p out
I'm guessing there's a "-dev" package missing but I can't figure out what it would be. Anyone else have some guesses?
pusalieth
Post
by pusalieth » Thu Nov 14, 2013 7:35 am
Hey I to had this problem and was able to install it using a shotgun approach, here is a list of things done.
Added ffmpeg PPA: ppa:jon-severinsson/ffmpeg
sudo apt-get update; sudo apt-get autoclean; sudo apt-get -y autoremove; sudo apt-get -y dist-upgrade;
sudo apt-get install libavutil-extra-51
sudo apt-get install build-essential libc6-dev libssl-dev libexpat1-dev libavcodec-dev libgl1-mesa-dev libqt4-dev
And it worked, let me know if you had any problems and maybe I have packages you don't
Running Mint 64 Cinnamon
barney_1
Post
by barney_1 » Thu Nov 14, 2013 3:53 pm
thanks pusalieth, that fixed it for me.
I did have to uninstall the bleeding edge libav I compiled as a previous attempt to get this build to happen (sudo make uninstall).
If anyone is wondering, here's the ffmpeg info after installing from that ppa:
ffmpeg -version
ffmpeg version N-38577-g5231eec
patgul
Post
by patgul » Thu Nov 14, 2013 8:20 pm
a ppa won't help me as i'm on debian. And since i'm too lazy to mess around with ffmpeg compilation i just bought a key to use it with 1.8.5 (and spend the rest of the time with the kids)...
Nonetheless i am interested in a fix.
And Jon's ppa says it is sporting version 0.10.9, how can that succeed if a version >2.0 is needed?
pusalieth
Post
by pusalieth » Thu Nov 14, 2013 10:41 pm
A ppa will work with Debian, just add the repository, Ubuntu and Mint are debian based. sudo add-apt-repository "insert deb repository here" "version here". The versian of Debian is relatable to the version of Ubuntu, such as Debian 7 is quantal. If you have an older version of Debian follow the examples below.
Examples;
Debain 7
(add repository)
add-apt-repository 'deb
http://ppa.launchpad.net/jon-severinsson/ffmpeg/ubuntu quantal main'
Older versions
(signing key)
sudo apt-key adv --keyserver keyserver.ubuntu.com --recv-keys CFCA9579
(add repository to sources list)
echo 'deb
http://ppa.launchpad.net/jon-severinsson/ffmpeg/ubuntu quantal main' >> /etc/apt/sources.list
And depending on whether you use the 16-bit audio encoding or 24-bit, you may have to compile a newer version, but this should give your system all the base packages.
