Aliexpress BU40N inside USB3.0 enclosure. How to in Archlinux...
UltraRip
Post by UltraRip »
BU40N (INIC-1618L enclosure) – Stable UHD ripping on Linux (Arch)
First, thanks to the MakeMKV community for the tooling and documentation around UHD-friendly drives.
This post documents a reproducible setup for stabilizing a BU40N drive in a USB enclosure based on the INIC-1618L bridge, specifically under Linux where UASP-related issues can cause disconnects during UHD reads.
Hardware / Software Stack
  • Drive: BU40N (UHD-friendly, reflashed to firmware 1.03)
  • Enclosure: INIC-1618L (USB 3.0, single micro-B port)
  • OS: Arch Linux
  • Kernel: 6.19
  • MakeMKV: 1.18.3
The enclosure supports SAT passthrough and firmware flashing without disassembly.
Observed Failure Modes (Linux only)
All issues below were reproducible under Linux but not present in Windows 10:
  • USB device reset/disconnect during reads of dual-layer UHD (66GB) media
  • Intermittent mount failures / excessive spin-up retries
  • Inconsistent readability across UHD discs (especially layer transitions)
  • Excessive seek noise during TOC read / initial access
  • Device disconnect when inserting media with MakeMKV already polling the drive
Root Cause (Likely)
The INIC-1618L bridge advertises UASP support, but in practice:
  • UASP command queueing conflicts with optical drive behavior
  • Layer transitions (L0 → L1) introduce latency interpreted as timeouts
  • This triggers USB resets at the bridge level (visible in dmesg)
This aligns with known instability of UASP for optical media, especially UHD Blu-ray.
Mitigation: usb-storage quirks (disable UASP + stabilize probing)
Force fallback to BOT (Bulk-Only Transport) and reduce aggressive probing:
options usb-storage quirks=13fd:0840:mku
Where:
  • 13fd:0840 → INIC-1618L VID:PID
  • u → disables UASP (critical)
  • m → reduces aggressive probing
  • k → avoids HID report ID conflicts (bridge quirk)
Implementation (Arch Linux)
  1. Identify device:
    lsusb
    Example:
    Bus 003 Device 005: ID 13fd:0840 Initio Corporation INIC-1618L SATA
  2. Create quirk config:
    echo 'options usb-storage quirks=13fd:0840:mku' | sudo tee /etc/modprobe.d/usb-storage-quirks.conf
  3. Include in initramfs:
    sudo nano /etc/mkinitcpio.conf
    Modify:
    FILES=(/etc/modprobe.d/usb-storage-quirks.conf)
  4. Rebuild initramfs:
    sudo mkinitcpio -P
  5. Reboot
Verification
cat /sys/module/usb_storage/parameters/quirks
Expected:
13fd:0840:mku
Also confirm in dmesg that:
  • Device binds to usb-storage (not uas)
  • No UAS driver attachment occurs
Multi-device quirks
Combine entries as comma-separated:
options usb-storage quirks=174c:1153:u,13fd:0840:mku
Example:
  • 174c:1153:u → disables UASP on ASM1153 bridge (UGREEN adapter)
Operational Notes (Important for stability)
  • Do not insert media while MakeMKV is open (avoid concurrent polling + spin-up)
  • Allow kernel to fully enumerate and stabilize (~5 seconds) before launching MakeMKV
  • Allow cooldown between long UHD reads (~30 minutes recommended)
  • Keep discs clean to reduce read retries
Alternative (Power-related instability)
If disconnects persist:
  • Remove drive from enclosure
  • Use a powered SATA → USB adapter
  • Use a Slimline SATA adapter
This helps mitigate power delivery limitations of some enclosures.
What NOT to do
  • Avoid USB hubs (even powered)
  • They add latency and increase transport-level instability
  • They can worsen UASP-related issues
Summary
The key fix is:
Disable UASP ("u" quirk) for INIC-1618L-based enclosures
Everything else is secondary tuning.
georgesgiralt
Re: Aliexpress BU40N inside USB3.0 enclosure. How to in Archlinux...
Post by georgesgiralt »
Thank you, this explains some strange things I get.
Could you post a link for your metal enclosure ? I'm looking for one...
UltraRip
Post by UltraRip »
georgesgiralt wrote:
Wed Apr 01, 2026 4:35 am
Hi!, I added the link to the Aliexpress item in the main post. Take into account that there are several similar enclosures in Aliexpress, some of them include 2 cables which you would need to connect simultaneously to 2 USB ports in your PC, and there are other enclosures which have only one USB 3.0 cable, this is the one I'm using. The drive that I purchased came already inside this kind of enclosure.
I think this is the same enclosure I'm using:
https://es.aliexpress.com/item/1005008737120645.html
If you still have USB bridge reset problems, you can open the enclosure and use use a SATA to USB3.0 adapter with external power supply like this, which I use to backup my movies in HDDs:
https://www.amazon.com/dp/B00MYU0EAU
And an additional Sata to Mini-sata adapter like this:
https://www.amazon.com/dp/B00S6I9D7E
This also worked for me before using the quirks configuration, allowing me to read a 2 layer UHD disk that was having issues, but it still can throw some errors in dmesg.
Another alternative is to use a powered USB3.0 hub.
georgesgiralt
Thank you !
