MakeMKV 1.18.1 archives double-compressed
STrRedWolf
Post by STrRedWolf »
The releases of MakeMKV for Linux were run through with GZip twice, making unarchiving them fail if you just use (for example)
tar xfvz makemkv-oss-1.18.1.tar.gz
To work around this, run "gunzip" on the archive, then rename the files to add the ".gz". Verify with the "file" command (it reads the file to verify what they actually are).
Nihilus
Re: MakeMKV 1.18.1 archives double-compressed
Post by Nihilus »
Same for 1.18.2.
16442496
Post by 16442496 »
Nihilus wrote:
Fri Oct 03, 2025 10:58 am
Same for 1.18.2.
Looks like it is Firefox thing.
Downloading with "wget" it works normal.
Debian
MakeMKV 1.17.6 (Registered)
DVD to MKV only.
Nihilus
Post by Nihilus »
Indeed. Firefox sends the "Accept-Encoding: gzip, deflate, br, zstd" header. Pass it to wget and you get double compression as well. The web server does return the "Content-Encoding: gzip" header, so that's weird. Not sure it's supposed to work like that.
Also, to unpack without renaming the intermediate file, just do
gunzip -c makemkv-oss-1.18.2.tar.gz | tar xvzf -
