Hi, I have random segfaults. Often makemkv works fine, but in the same time makemkvcon has segfaults. Sometimes this situation averts.
dmesg: makemkvcon[1406]: segfault at 96119000 ip b766e126 sp 9610efe0 error 4 in libdriveio.so.0[b766d000+5000]
1.6.7 segfault in libdriveio.so
- Contact:
Re: 1.6.7 segfault in libdriveio.so
When it happens, please capture core dump and send it with libdriveio.so that you've built on your system to support@makemkv.com . Are there any messages in debug log?
It happends on start. Today I can't get any segfaults.
Maybe some kind of hardware failure.
- Contact:
A confirmed bug. Please post information about your drive requested at http://www.makemkv.com/forum2/viewtopic.php?f=1&t=3463
cd-info version 0.81 i486-pc-linux-gnu
Copyright (c) 2003, 2004, 2005, 2007, 2008 R. Bernstein
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
CD location : /dev/cdrom
CD driver name: GNU/Linux
access mode: ioctl
Vendor : ATAPI
Model : iHAS122 B
Revision : ZL03
Hardware : CD-ROM or DVD
Can eject : Yes
Can close tray : Yes
Can disable manual eject : Yes
Can select juke-box disc : No
Can set drive speed : No
Can read multiple sessions (e.g. PhotoCD) : Yes
Can hard reset device : Yes
Reading....
Can read Mode 2 Form 1 : Yes
Can read Mode 2 Form 2 : Yes
Can read (S)VCD (i.e. Mode 2 Form 1/2) : Yes
Can read C2 Errors : Yes
Can read IRSC : Yes
Can read Media Channel Number (or UPC) : Yes
Can play audio : Yes
Can read CD-DA : Yes
Can read CD-R : Yes
Can read CD-RW : Yes
Can read DVD-ROM : Yes
Writing....
Can write CD-RW : Yes
Can write DVD-R : Yes
Can write DVD-RAM : Yes
Can write DVD-RW : No
Can write DVD+RW : No
__________________________________
Disc mode is listed as: DVD-ROM
CD-ROM Track List (1 - 1)
#: MSF LSN Type Green? Copy?
1: 00:02:00 000000 data false no
170: 95:59:74 431849 leadout (968 MB raw, 843 MB formatted)
CD Analysis Report
ISO 9660: 2252462 blocks, label `ADAPTACJA '
Application:
Preparer :
Publisher :
System :
Volume : ADAPTACJA
Volume Set : UNDEFINED
UDF: version 1.02
PARTICULAR PURPOSE.
access mode: ioctl
Vendor : ATAPI
Model : iHAS122 B
Revision : ZL03
Can eject : Yes
Reading....
Can read IRSC : Yes
Can read CD-R : Yes
Writing....
CD Analysis Report
Application:
Preparer :
Publisher :
System :
Volume : ADAPTACJA
UDF: version 1.02
