[SOLVED] shouldn't a key in KEYDB.cfg be enough?
jemima
Post by jemima »
Hey.
I have a UHD BluRay for which the SHA1 of AACS/Unit_Key_RO.inf already has an entry in the well-known KEYDB.cfg file.
Shouldn't that be already enough to play it with e.g. mpv? I mean without the need to process it with MakeMKV or similar first?
But mpv complains about an unknown file format so I presume decryption has failed (while that works for normal blurays).
Thanks,
Jemima
jemima
Re: shouldn't a key in KEYDB.cfg be enough?
Post by jemima »
I think I might have found the answer for why it didn't work. Since it's likely no Linux issues, I posted my assumption (asking for confirmation) in a new thread in the general forum.
