1.4.2 beta / title was skipped
scarf
Post by scarf »
hi. thanks for bringing this application to the open source community. i will share my first experience with it, attempting to convert a blu-ray disc structure on my hard disk. the problems i have may be due to the blu-ray files and not makemkv.
i am using ubuntu 8.10 x86_64 with linux-2.6.27-11-generic. the application has compiled and opened fine.
i have gone to 'file > open files' and selected the index.bdmv. i have enabled 'log debug messages', but i cannot copy any of the text and post it here. is a log file made somewhere? can you tell me how to easily post it? there are several FAILURE error messages and the final result is 'title 0001.m2ts was skipped'. if i continue and try to make the MKV anyway, there are more FAILURE errors, 'error while reading input', and 'unable to save title'.
i have tried watching all of the m2ts files with mplayer, and there were several hiccups during playback but overall i was able to watch the entire movie. here is the output of mplayer during playback:
$ gmplayer *.m2ts
MPlayer 1.0rc2-4.3.2 (C) 2000-2007 MPlayer Team
CPU: AMD Phenom(tm) 9950 Quad-Core Processor (Family: 16, Model: 2, Stepping: 3)
CPUflags:  MMX: 1 MMX2: 1 3DNow: 1 3DNow2: 1 SSE: 1 SSE2: 1
Compiled with runtime CPU detection.
xscreensaver_disable: Could not find XScreenSaver window.
/usr/share/fonts/truetype/ttf-dejavu/DejaVuSans.ttf doesn't look like a bitmap font description, ignoring.
Cannot load bitmap font: /usr/share/fonts/truetype/ttf-dejavu/DejaVuSans.ttf
mplayer: could not connect to socket
mplayer: No such file or directory
Failed to open LIRC support. You will not be able to use your remote control.
Playing BDMV/STREAM/00001.m2ts.
TS file format detected.
VIDEO H264(pid=4113) AUDIO A52(pid=4353) NO SUBS (yet)!  PROGRAM N. 1
FPS seems to be: 23.976025
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Forced audio codec: mad
Opening audio decoder: [liba52] AC3 decoding with liba52
Using SSE optimized IMDCT transform
Using MMX optimized resampler
AUDIO: 48000 Hz, 2 ch, s16le, 448.0 kbit/29.17% (ratio: 56000->192000)
Selected audio codec: [a52] afm: liba52 (AC3-liba52)
AO: [alsa] 48000Hz 2ch s16le (2 bytes per sample)
Starting playback...
VDec: vo config request - 1920 x 1080 (preferred colorspace: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.78:1 - prescaling to correct movie aspect.
VO: [xv] 1920x1080 => 1920x1080 Planar YV12
[Mixer] No hardware mixing, inserting volume filter. 14%  1.1% 0 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors42% 14%  1.5% 0 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  1.7% 0 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors5 59% 10%  2.3% 19 0
A:1122.5 V:1122.6 A-V: -0.058 ct: -0.068 12527/12527 59% 10%  2.3% 19 0
(<unknown>:7857): Pango-WARNING **: failed to create cairo scaled font, expect ugly output. the offending font is 'DejaVu Sans 9.9990234375'
(<unknown>:7857): Pango-WARNING **: shaping failure, expect ugly output. shape-engine='BasicEngineFc', font='DejaVu Sans 9.9990234375', text='[h264 @ 0xf8ce80]'
[h264 @ 0xf8ce80]illegal short term buffer state detected
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.2% 21 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.0% 25 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.3% 44 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors3 60% 10%  2.3% 45 0
[h264 @ 0xf8ce80]illegal short term buffer state detected10%  2.3% 45 0
A:1577.3 V:1577.4 A-V: -0.106 ct: -0.145 23430/23430 60% 10%  2.2% 45 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors4 60% 10%  2.2% 45 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.2% 45 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.2% 48 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.2% 50 0
A:1862.3 V:1862.0 A-V:  0.329 ct: -0.185 30255/30255 60% 10%  2.2% 52 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.3% 60 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.3% 68 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.3% 70 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.3% 93 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors3 60% 10%  2.1% 99 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 99 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 104 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 105 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors4 60% 10%  2.1% 123 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors7 60% 10%  2.1% 123 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 123 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.2% 143 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.2% 145 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors8 60% 10%  2.2% 146 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors9 60% 10%  2.2% 146 0
[h264 @ 0xf8ce80]illegal short term buffer state detected10%  2.2% 146 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors1 60% 10%  2.2% 146 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.2% 149 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.2% 151 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors8 60% 10%  2.2% 152 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors7 60% 10%  2.1% 152 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 152 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 156 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 158 0
A:3840.6 V:3840.6 A-V:  0.019 ct: -0.518 77685/77685 60% 10%  2.2% 182 0
Playing BDMV/STREAM/00002.m2ts.
VO: [xv] 1920x1080 => 1920x1080 Planar YV12  [fs]
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors% 10%  1.1% 0 0
[h264 @ 0xf8ce80]illegal short term buffer state detected 1.1% 0 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors59% 10%  1.5% 0 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors1.5% 0 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors1.5% 1 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors4 60% 10%  2.1% 18 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors1 60% 10%  1.9% 18 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors0 60% 10%  1.9% 18 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors3 60% 10%  1.9% 18 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  1.8% 18 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors0 60% 10%  1.9% 23 0
[h264 @ 0xf8ce80]illegal short term buffer state detected10%  1.9% 23 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  1.9% 23 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors8 60% 10%  2.1% 41 0
[h264 @ 0xf8ce80]illegal short term buffer state detected10%  2.1% 41 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors8 60% 10%  1.9% 41 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  1.9% 44 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 55 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors6 60% 10%  2.0% 66 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors3 60% 10%  2.0% 66 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors2 60% 10%  2.0% 66 0
[h264 @ 0xf8ce80]illegal short term buffer state detected10%  2.0% 66 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.0% 66 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 78 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 86 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 91 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 93 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 95 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors7 60% 10%  2.1% 99 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors2 60% 10%  2.0% 99 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors5 60% 10%  2.0% 99 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors6 60% 10%  2.0% 99 0
[h264 @ 0xf8ce80]illegal short term buffer state detected10%  2.0% 99 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors8 60% 10%  2.0% 99 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.0% 99 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors9 60% 10%  2.1% 133 0
[h264 @ 0xf8ce80]illegal short term buffer state detected10%  2.1% 133 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors2 60% 10%  2.1% 133 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors1 60% 10%  2.1% 133 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors7 60% 10%  2.1% 133 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors4 60% 10%  2.1% 133 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.0% 133 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.1% 135 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors1 60% 10%  2.0% 138 0
[h264 @ 0xf8ce80]illegal short term buffer state detected10%  2.0% 138 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors  2.0% 138 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors6 63% 10%  1.5% 0 0
A:7077.5 V:7077.4 A-V:  0.021 ct:  0.015 77726/77726 61% 10%  1.6% 3 0
Playing BDMV/STREAM/00003.m2ts.
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors2.0% 3 0
[h264 @ 0xf8ce80]concealing 6120 DC, 6120 AC, 6120 MV errors2.0% 5 0
[h264 @ 0xf8ce80]concealing 0 DC, 0 AC, 0 MV errors49% 10%  1.8% 9 0
A:7406.5 V:7406.5 A-V:  0.022 ct: -0.081 7888/7888 48% 11%  1.7% 9 0
Exiting... (Quit)
Re: 1.4.2 beta / title was skipped
Post by mike admin »
Please try opening the same disc with console version like "makemkvcon info disc:0" and "makemkvcon mkv disc:0 all ~/blabla" - it will output everything to stdout.
scarf
Post by scarf »
thanks.
i have gone to the directory just above where the index.bdmv file and the STREAM directory, etc. are and issued 'makemkvcon info file:.' and then ' makemkvcon mkv file:. all /tmp/blabla':
$ makemkvcon info file:.
Current action: Scanning CD-ROM devices
Current progress - 0%  , Total progress - 0%
ERR: FAILURE: code=00000000 src=XtO|prxXVd%BGV85@faU:213130099
001012:000000:0020 FAILURE: Code 0 at XtO|prxXVd%BGV85@faU:213130099
Current progress - 100%  , Total progress - 0%
Current progress - 100%  , Total progress - 100%
Current progress - 0%  , Total progress - 100%
003006:000000:0000 Opening files on harddrive at .
Current action: Pre-calculating data
Current action: Processing AV clips
Current action: Processing movie playlists
Current action: Decrypting
003310:000000:0000 AACS directory not present, assuming unencrypted disc
Current action: Processing titles
Current progress - 25%  , Total progress - 0%
Current progress - 25%  , Total progress - 2%
ERR: FAILURE: code=00000007 src=SaJ`X9UjZjV$}%@GV&%w:213132790
ERR: FAILURE: code=00000000 src=>sx<@].,jpT6{5k[]Q}k!:213132123
ERR: FAILURE: code=00000000 src=>sx<@].,jpT6{5k[]Q}k!:29395908
ERR: FAILURE: code=00000000 src=EMgDC,rKLOKb.=:"'K`:29393746
ERR: FAILURE: code=00000000 src=Cgio=ZMOY<v`>1#TJ:213132399
ERR: FAILURE: code=00000000 src=O|h,DuD.bTzby[7y:213134354
003313:000000:0000 File 00002.m2ts was added as title #0
001012:000000:0020 FAILURE: Code 7 at SaJ`X9UjZjV$}%@GV&%w:213132790
001012:000000:0020 FAILURE: Code 0 at >sx<@].,jpT6{5k[]Q}k!:213132123
001012:000000:0020 FAILURE: Code 0 at >sx<@].,jpT6{5k[]Q}k!:29395908
001012:000000:0020 FAILURE: Code 0 at EMgDC,rKLOKb.=:"'K`:29393746
001012:000000:0020 FAILURE: Code 0 at Cgio=ZMOY<v`>1#TJ:213132399
005043:000000:0000 Failed to decode audio/video data for title #1 - invalid mux or internal error, title skipped.
001012:000000:0020 FAILURE: Code 0 at O|h,DuD.bTzby[7y:213134354
003015:000000:0000 Title #00001.m2ts was skipped
Current progress - 75%  , Total progress - 2%
Current progress - 75%  , Total progress - 6%
003313:000000:0000 File 00003.m2ts was added as title #1
Current progress - 100%  , Total progress - 6%
Current progress - 100%  , Total progress - 8%
005011:000000:0000 Operation sucessfully completed
Total 2 titles
Title  0
0 Video Mpeg4
1 Audio Dolby Digital
2 Audio Dolby Digital
3 Audio DTS
4 Subtitles HDMV PGS Subtitles
5 Subtitles HDMV PGS Subtitles
6 Subtitles HDMV PGS Subtitles
Title  1
0 Video Mpeg4
3 Audio DTS
Current progress - 0%  , Total progress - 8%
$ makemkvcon mkv file:. all /tmp/blabla
ERR: FAILURE: code=00000002 src=`wK4UL4FqVPcaRYSR*"g'5.:29393447
ERR: FAILURE: code=00000000 src=?7e;fs}DR{3 IQ@Vi:29394413
005014:000000:0000 Saving 2 titles into directory /tmp/blabla
001012:000000:0020 FAILURE: Code 2 at `wK4UL4FqVPcaRYSR*"g'5.:29393447
001012:000000:0020 FAILURE: Code 0 at ?7e;fs}DR{3 IQ@Vi:29394413
005004:000000:0000 0 titles saved, 2 failed
The titles were skipped because of non-conformant mpeg-4 elementary stream. Whak kind of disc is it? Was it a standard blu-ray disc or it was created by some tool? We've seen the same problem with some "blu-ray rips" that were incorrectly multiplexed. The secon error is rather ugly - it failed because /tmp/blabla directory did not exist.
scarf
Post by scarf »
it is probably as you say a 'bad rip', or non-compliant, or something using non-standard method. i can't see any info regarding how it was created, but i do see that i should be able to burn the files to double-layer dvd and playback on AVCHD player like PS3... so, kinda strange processing was done, it seems.
