Error 'Posix error - Permission denied' occurred while creating
jbnouser
Post by jbnouser »
When I mount an external USB Hard Drive and then set makemkv's output folder as a directory on that hard drive, I get an error when I try to save DVDs and BluRays:
Error 'Posix error - Permission denied' occurred while creating /media/username/MovieName
I never receive this error when I try to save files in my home directory. The problem only occurs on externally mounted disks. I tried adding full permissions to that directory (chmod 0777 .), but that does not help.
Has anyone run into this problem on Linux? How can I solve it?
bmillham
Re: Error 'Posix error - Permission denied' occurred while creating
Post by bmillham »
Unless label of the drive is MovieName, that's your problem. The path should be:
/media/username/drivelabel
jbnouser
Post by jbnouser »
Okay. You're right. The path name in my post was incorrect. I did not want to use my real user name. When I run makemkv, I use the correct path name. It's something like:
 /media/username/drivelabel/videos/MovieName
The point is that I have full write permissions in that directory. I can create files from the linux command-line. However, if I try to use that directory as the output folder in makemkv, then I get permission errors. How can I fix this?
bmillham
Post by bmillham »
I'm not sure why you are really worried about that. But.. The problem wasn't with that part of the path, it was the missing drive part.
So what happens if you try this from the shell:
touch /media/username/drivelabel/videos/MovieName/testfile
And what does:
ls -ld /media/username/drivelabel
show?
EDIT:
It would help to know how the drive is formatted. EXT? NTFS? FAT? etc.
You could always just try this:
sudo chown -R username:username /media/username/drivelabel
to force the ownership/group of everything on the drive to be you.
jbnouser
Post by jbnouser »
Hi, thanks for your help.
I was able to create the testfile with the touch command.
The results of the 'ls -ld' are:
> ls -ld /media/USERNAME/drivelabel/NetFlix/MovieName
drwxr-xr-x 2 USERNAME USERNAME 4096 Jul  1 14:00 /media/USERNAME/drivelabel/NetFlix/MovieName
I also tried the 'chown' command you suggested, but it did not help.
The hard drive is formatted as an NTFS drive.
The problem also persists if I mount a different partition on the main disk. That filesystem would be an ext filesystem.
bmillham
Post by bmillham »
The only think that I can think of is that MakeMKV isn't running as your user. Did you install from source?
While MakeMKV is running, what user is MakeMKV running as?
ps -ef | grep -i makemkv
Will show what user makemkv is running as (and makemkvcon).
jbnouser
Post by jbnouser »
I am running it as my user. In fact, I simply start it from the command-line.
makemkv is installed as a snap. I must admit I don't know what that is. It's installed in something like: /snap/makemkv/351 I don't know how that works so, naturally, I'm suspicious of it.
bmillham
Post by bmillham »
Did you try the ps command that I suggested to verify what user MakeMKV is running as?
Instead of a snap, why don't you just install it? It's not that difficult.
bmillham
Post by bmillham »
I did a little digging into how snaps work, and I'm now convinced that your problem is with the snap.
You have to give the snap access removable media. Have a look at this link for more info:
https://www.linuxandubuntu.com/home/sna ... ermissions
jbnouser
Post by jbnouser »
I'm not sure why I used a snap originally. I followed your advice and installed makemkv directly and it works now. It allows me to save files to the externally mounted hard drive. Thank you very much for your help!
