Fails to read blu-ray disc
gpborges
Post by gpborges »
Hi, I've setup an HTPC with Mythbuntu 10.04 and have successfully installed MakeMVK. I was trying to watch/rip my first Bluray but I can't. I've set already my /dev/shm to 777 and it didn't help. Look my debug:
gpborges@htpc-backend:/data$ sudo chmod -R 777 /dev/shm/
[sudo] password for gpborges:
gpborges@htpc-backend:/data$ makemkvcon --debug info disc:0
MakeMKV v1.5.8 linux(x86-release) started
Debug logging enabled, log will be saved as /home/gpborges/MakeMKV_log.txt
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0117E630E4F82A27A8896DE3116EFF8D775 to device 'SG:dev_11:0'
DEBUG: Code 0 at Dkum4Ld4]'z;(t#r8{G-:29394390
DEBUG: Code 0 at C]H4zb-0hh|Ox6,]ia:29394183
DEBUG: Code 0 at C]H4zb-0hh|Ox6,]ia:213130191
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..04045DFC9B9EC24FDC6D227739F441097A0 to device 'SG:dev_11:0'
DEBUG: Code 1 at C]H4zb-0hh|Ox6,]ia:213130191
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..05E77CA6ADE0700FA576A0D6AAC4A29F11B to device 'SG:dev_11:0'
DEBUG: Code 2 at C]H4zb-0hh|Ox6,]ia:213130191
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..041991DFB9094DA84A3C39438CE170A289C to device 'SG:dev_11:0'
DEBUG: Code 3 at C]H4zb-0hh|Ox6,]ia:213130191
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..05DFFE81F2B11677F4B1AC860B6B2FBF0C3 to device 'SG:dev_11:0'
DEBUG: Code 4 at C]H4zb-0hh|Ox6,]ia:213130191
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..08FD7FA317938CB904FC54E8537E8A22742 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occured while issuing SCSI command AD010..080002400 to device 'SG:dev_11:0'
DEBUG: Code 0 at Dkum4Ld4]'z;(t#r8{G-:29393930
DEBUG: Code 0 at C]H4zb-0hh|Ox6,]ia:121262716
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..05C35CF269C541F2E4BB41655CE8ABCF78C to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0ACC1FED64E2F95AEC9FCC8CCD86D945F73 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..012A7B49C403C08D6C4C03AB3B8F0E1D121 to device 'SG:dev_11:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occured while issuing SCSI command A30..00200740100720..0AAE37B6A8A553CB1F5CBBDB34DD777D1CE to device 'SG:dev_11:0'
DEBUG: Code 0 at %7lV"7@@X(1,*#W.#9+:121263590
DEBUG: Code 0 at %7lV"7@@X(1,*#W.#9+:29396943
Total 0 titles
Anyone would know what else could I try? And I'm a member of all groups, including cdrom0.
gpborges
Re: Requires root to run? [SOLVED]
Post by gpborges »
Here some more info about my bluray player. It's a Sony Optiarc BD ROM BC-5500S4
Output of command lshw for my bd rom:
*-cdrom
                description: DVD-RAM writer
                product: BD ROM BC-5500S4
                vendor: Optiarc
                physical id: 1
                bus info: scsi@1:0.0.0
                logical name: /dev/cdrom1
                logical name: /dev/cdrw1
                logical name: /dev/dvd1
                logical name: /dev/dvdrw1
                logical name: /dev/scd0
                logical name: /dev/sr0
                logical name: /media/SHUTTER_ISLAND_AC
                version: 1.Va
                capabilities: removable audio cd-r cd-rw dvd dvd-r dvd-ram
                configuration: ansiversion=5 mount.fstype=udf mount.options=ro,nosuid,nodev,relatime,uid=1000,gid=1000,umask=77,iocharset=utf8 state=mounted status=ready
              *-medium
                   physical id: 0
                   configuration: mount.fstype=udf mount.options=ro,nosuid,nodev,relatime,uid=1000,gid=1000,umask=77,iocharset=utf8 state=mounted
Re: Fails to read blu-ray disc
Post by mike admin »
Very possible problem with your drive. Please try to find updated firmware for your drive.
drewg
Post by drewg »
Your error messages look like what I get on Ubuntu when I do not run as root. Try running under sudo and see if that helps.
Drew
