Hi
I've just installed MakeMKV Beta v1.4.12 on Ubutntu 9.10 (AMD64), and everything seems to start OK. There's an error saying that no optical drive was found (because I don't have one), but this is OK, because this is a headless box in a cupboard that I only want to use for converting ISO files.
When I try to select source files and browse to my ISO files, nothing appears, regardless of the file type I select.
Any idea?
No Source Files Available
- Contact:
Re: No Source Files Available
You may have found a bug. Please see if file extension is ISO (uppercase) and rename it to have iso (lowercase) entension if it is. Please post here if it solves the problem.
