BDR-XD05S Flashable?
totalmassretain
Post by totalmassretain »
Hello, wondering if my Pioneer BDR-XD05S drive is flashable
OS device name: /dev/sr2
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 3.10
Serial number:
Firmware date: 2017-06-22
Highest AACS version: 65
Drive platform: RS8232
Firmware name: PIONEER BDR-XD05
Firmware version: 3.10/ID34
Re: BDR-XD05S Flashable?
totalmassretain wrote:
Thu Sep 25, 2025 7:47 pm
Revision: 3.10
Serial number:
PM sent.
totalmassretain
Coopervid wrote:
Fri Sep 26, 2025 8:18 am
Revision: 3.10
Serial number:
PM sent.
Getting a "Drive and Firmware Hardware types don't match error"
Sat Sep 27, 2025 12:39 am
Revision: 3.10
Serial number:
PM sent.
Check the force box
totalmassretain
MartyMcNuts wrote:
Sat Sep 27, 2025 2:02 am
PM sent.
Check the force box
Still getting the same error. Running Win 10 on a VM if thats of any importance
Sat Sep 27, 2025 2:13 am
Check the force box
a lot of VM's don't work.
Check the force box
Try VMWare or get help from a friend with a Windows PC.
totalmassretain
Coopervid wrote:
Sat Sep 27, 2025 9:12 am
Check the force box
Installed Windows 11, still getting the same error. Here's a screenshot...
https://imgur.com/a/qbXeEVt
Sat Sep 27, 2025 6:48 pm
The problem is clearly on your side.
Make sure no disc in drive and drive is closed.
As depicted in the tutorial you need to load 2 files. Firmware and kernel.
You need to check force flash.
After flashing you need to remove all power from the drive if you have a power supply and also USB.
READ the tutorial and follow it by the book!
As replied by PM you were trying to flash some files from an obscure source. I don't even have these firmware files. Try the ones from the package and it will work.
