makemkv LG WH16NS60 4K UHD no disc inserted
jravin
Post by jravin »
I see several threads about this (topic), but I have not found a solution yet. Of course I have tried rebooting, removing the drive, adding it back, blinking twice then turning it on, et cetera. All to no avail, so far.
I am running Windows 11, with an new LG WH16NS60 from NewEgg. It is in an 'OWC Mercury Pro 5.25" Optical Drive External Enclosure (NO Drive)' from Amazon. And I am using a "JSAUX USB 3.0 Cable B Male to USB-C, 6.6ft USB 3 Type B Cord Nylon Briaded" cable. The discs are also brand new, specifically all four of the Matrix films, in 4K UHD.
My current setup, according to MakeMKV BETA v1.18.1:
Product: BD-RE WH16NS60
Revision: 1.01
Serial number: SIK94G81I571
Firmware date: 2117-11-20 20:00
Highest AACS version: 61
Firmware version: 1.01
MakeMKV was giving me issues about a license or something, and I was using a temporary fix license, but am currently using this license: MakeMKV is free while in beta If I need to buy the software, that is fine by me.
I used the Ultimate UHD Drives Flashing Guide Updated 2025 as my guide. The guide provides different paths towards the same end, which is great, but also confusing. This link says to use various firmware upgrade tools, and to download the firmware from Google Drive Link.
If you want me to upgrade, please provide the makemkvcon64.exe command line you want me to use. The current --help does not show a lot of the options and parameters which I have read within this forum. I have been using the "How To Flash Videos and commands:" section of the Ultimate UHD Drives Flashing Guide, but am not quite sure if I need to use the encryption option or not. "HL-DT-ST-BD-RE_WH16NS60-1.03-N000600-212005081010.bin" appears to be the only version which is encrypted, according to the Ultimate UHD Drives Flashing Guide. The Ultimate UHD Drives Flashing Guide has a link for LG drives, and it points to this ASUS related thread: Re: Firmware downgrade using official (patched) flasher, the "Ultra hax0r guide". Again, I would rather use the makemkvcon64.exe program for flashing.
Please advise.
Also, side note, the https://www.makemkv.com/faq/ link seems to be broken.
// Win11,LG WH16NS60,OWC Mercury Pro 5.25" Optical Drive External Enclosure,JSAUX USB 3.0 Cable B Male to USB-C, 6.6ft USB 3 Type B Nylon Briaded Cord
Re: makemkv LG WH16NS60 4K UHD no disc inserted
jravin wrote:
Fri Aug 22, 2025 4:14 am
Revision: 1.01
Please advise.
Your drive is already libredrive enabled and UHD compatible. No need to flash. Just clean the discs before trying again.
jravin
Post by jravin »
MartyMcNuts wrote:
Sat Aug 23, 2025 12:19 am
@MartyMcNuts, as creative a remedy you have provided, I am not sure how to express that this issues seems to go beyond a dirty disc. Perhaps if "clean the discs" is code for some extremely complex recompiling of the disc similar to a disk defragmentation, then maybe this is something to explore.
Perhaps we can move forward with the assumption that the discs are clean. Also, before anyone mentions it, the computer is powered on!
What might the next step in trouble-shooting this issue possibly be?
Just because a disc is brand new, right out of the package doesn't mean it is clean. I've had to clean several brand-new discs to get them to rip.
If you want to move past the obvious answer, then get another copy of the disc. And perhaps get an additional drive. Personally, I have four different optical drives on my desk. Sometimes a drive just doesn't seem to like a particular disc. Often when this is the case, one of my other drives will read the disc easily. On very rare occasions, I end up with a disc that won't work in any of my drives regardless of how much cleaning of the disc I do. In that handful of cases, a replacement disc has worked for me.
jravin
Post by jravin »
Wipe the disc.
Try a different disc.
Try a different drive.
Not the responses I was after, but if that is all I am getting, so be it.
Thank you.
jravin wrote:
Mon Aug 25, 2025 6:14 am
Wipe the disc.
Thank you.
Cleaning the disc, usually means with soapy water and a soft microfiber cloth. Some people use glasses cleaner spray to clean the discs. They often have an invisible to the naked eye layer of film on them from the manufacturing process.
VA1DER
Post by VA1DER »
MartyMcNuts wrote:
Tue Aug 26, 2025 3:07 am
My go-to is a solution I originally made for print head cleaning, but it works very well on discs as it leaves no residue.
Simply one part household ammonia, one part distilled water, and two parts isopropanol or denatured ethanol (better).
Just remember that ammonia over (a fair amount of) time will make polycarbonate cloudy. So don't soak your disc with it or use this daily. But for an initial clean it works great.
My own wh16ns60 has problems with about 25% of new UHD discs until I clean them.
I just use liquid soap and warm water.
jravin
Post by jravin »
Note timestamps of quotes ...
jravin wrote:
Sat Aug 23, 2025 3:01 am
VA1DER wrote:
Tue Aug 26, 2025 5:58 am
Coopervid wrote:
Wed Aug 27, 2025 10:36 am
Interesting takeover of the thread. Way to read the OP's (my) request and go the exact opposite direction with it.
As for the actual topic, since my drive was using firmware 1.01, I thought I would try getting it to 1.02, and here is what happened:
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f --all-yes -d D: rawflash -i C:\Users\username\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Reading input file C:\Users\username\Downloads\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS60_1.01_211711202000_SIK94G81I571
100% Operation finished
Program Flash NG 06/29/00
Command produced error code 0x82062900
This sent me searching the forum for "0x82062900" threads. I found a few, but the general consensus is to ignore this error. (Not sure why the error is displayed if we are supposed to ignore it. Perhaps add a verbose option which would include errors which can be ignored otherwise they are not displayed.) Even so, I reran the exact same firmware upgrade because ... do the same thing and expecting different results ...
Current Drive ID: HL-DT-ST_BD-RE__WH16NS60_1.02_211810291936_SIK94G81I571
Done successfully
This then yielded:
Revision: 1.02
Highest AACS version: 76
Firmware version: 1.02
I put in one disc that has been thus far unreadable, and it read it first attempt. I could tell the drive was doing something different because it was not making little clicking noises trying to read the disc. Instead it read it nice and smooth, which is usually a good sign that the disc is being read and things will most likely work as intended. As I am typing this post makemkv is ripping the 4k UHD Casino disc. Once this is done I will try some of the other discs that were not reading.
Hopefully upgrading from 1.01 to 1.02 fixed the issue.
The https://www.makemkv.com/faq/ link still seems to be broken:
Warning: include(/home/makemkv/public_html/faq/nucleus/libs/globalfunctions.php): failed to open stream: No such file or directory in /home/u235770/makemkv.com/faq/config.php on line 31
Warning: include(): Failed opening '/home/makemkv/public_html/faq/nucleus/libs/globalfunctions.php' for inclusion (include_path='.:/nix/store/ncmrmkw1ags39sar7n38a843d9rns2xc-php-7.2.34/lib/php') in /home/u235770/makemkv.com/faq/config.php on line 31
Fatal error: Uncaught Error: Call to undefined function selector() in /home/u235770/makemkv.com/faq/index.php:12 Stack trace: #0 {main} thrown in /home/u235770/makemkv.com/faq/index.php on line 12
jravin
Post by jravin »
First and foremost, all discs are clean.
Secondary, et al, the update from 1.01 to 1.02 did NOT work as intended. The "Casino" rip did not turn out. I could not play it on several computers, using various software, or on an Android, or iPhone.
This drive will rip blu ray discs all day, producing crisp video and audio, along with subtitles, but the moment I put a UHD into the drive it loses its mind and decides it cannot even see the disc.
I am looking to try a WH16NS40.
In a way, my inability to rip UHD discs is saving me money, for now. Instead of dropping $$$ on UHD discs I went to a local 2nd hand shop and bought 20-30 DVD's and a couple Blu-Ray's, all for the price of one or two UHD movie(s).
