Pioneer BDR-S13UBK & MacOS Monterey 12.7.2
jositoft
Post by jositoft »
I have a MacPro5,1 running ML OpenCore 0.9.7 with Monterey 12.7.2. I had an LG drive that was dying. Every burn lately has been a coaster, even switching media. I replaced it with a Pioneer BDR-213UBK. This new drive seems to be causing kernel panics which cause the screen to go dark and for me to have push the power button, which shuts the computer down. I then have to turn it back on. It seems the new drive is going to sleep and upon trying to wake it, it crashes. Of course, Pioneer's mac drive management software is paltry, at best. When the drive works, it has an amazing success rate. I would hate to get rid of it but can't live with these crashes. Any help would be appreciated. Have included the crash log below. Thank you in advance!
panic(cpu 4 caller 0xffffff801e829591): IOSCSIPeripheralDeviceType05::setPowerState(0xffffff9f143582e0 : 0xffffff8020c81aea, 1 -> 4) timed out after 100410 ms @IOServicePM.cpp:5524
Panicked task 0xffffffad790de670: 281 threads: pid 0: kernel_task
Backtrace (CPU 4), panicked thread: 0xffffffa8ad853540, Frame : Return Address
0xffffffe8284e3a30 : 0xffffff801e079a3d
0xffffffe8284e3a80 : 0xffffff801e1dca26
0xffffffe8284e3ac0 : 0xffffff801e1cbd93
0xffffffe8284e3b10 : 0xffffff801e019a90
0xffffffe8284e3b30 : 0xffffff801e079e0d
0xffffffe8284e3c50 : 0xffffff801e0795c6
0xffffffe8284e3cb0 : 0xffffff801e9149d3
0xffffffe8284e3da0 : 0xffffff801e829591
0xffffffe8284e3e00 : 0xffffff801e828d59
0xffffffe8284e3e10 : 0xffffff801e84310e
0xffffffe8284e3e50 : 0xffffff801e827b98
0xffffffe8284e3e70 : 0xffffff801e0ccac5
0xffffffe8284e3ee0 : 0xffffff801e0cdb92
0xffffffe8284e3fa0 : 0xffffff801e01919e
Process name corresponding to current thread (0xffffffa8ad853540): kernel_task
Boot args: agdpmod=pikera shikigva=80 unfairgva=1 radgva=1 mbasd=1 -no_compat_check no32exec=0
Mac OS version:
21G1974
Kernel version:
Darwin Kernel Version 21.6.0: Thu Nov 9 00:38:19 PST 2023; root:xnu-8020.240.18.705.10~1/RELEASE_X86_64
Kernel UUID: ABAADB03-E25C-33B4-B3E0-574627B92635
KernelCache slide: 0x000000001de00000
KernelCache base: 0xffffff801e000000
Kernel slide: 0x000000001de10000
Kernel text base: 0xffffff801e010000
__HIB text base: 0xffffff801df00000
System model name: MacPro5,1 (Mac-7BA5B2D9E42DDD94)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 9638368565582
Last Sleep: absolute base_tsc base_nano
Uptime : 0x000008c41b88e2b4
Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000
Wake : 0x0000000000000000 0x000000133d9ac178 0x0000000000000000
Compressor Info: 1% of compressed pages limit (OK) and 3% of segments limit (OK) with 0 swapfiles and OK swap space
Zone info:
Zone map: 0xffffff98ab3d0000 - 0xffffffb8ab3d0000
. PGZ : 0xffffff98ab3d0000 - 0xffffff98ae3d1000
. VM : 0xffffff98ae3d1000 - 0xffffff9d7a96a000
. RO : 0xffffff9d7a96a000 - 0xffffff9f1409d000
. GEN0 : 0xffffff9f1409d000 - 0xffffffa3e0636000
. GEN1 : 0xffffffa3e0636000 - 0xffffffa8acbcf000
. GEN2 : 0xffffffa8acbcf000 - 0xffffffad79168000
. GEN3 : 0xffffffad79168000 - 0xffffffb245702000
. DATA : 0xffffffb245702000 - 0xffffffb8ab3d0000
Metadata: 0xffffffe7fef3c000 - 0xffffffe81ef3c000
Bitmaps : 0xffffffe81ef3c000 - 0xffffffe827f3c000`
Re: Pioneer BDR-S13UBK & MacOS Monterey 12.7.2
I'm just guessing, but maybe there's a eco mode or something on the drive that's causing trouble? The first line of the dump suggests a SCSI peripheral is trying to set a power state and panicking the kernel. Maybe there's a way to turn any eco modes off?
Also, kudos to you for rockin' a cheese grater. Do you have a 2010 Westmere or a 2012 Nehalem?
